interface-config-radio-instance
Configures a radio‘s channel of operation
Only a trained installation professional should define the radio channel. Select Smart for the radio to scan non-overlapping channels listening for beacons from other access points. After the channels are scanned, the radio selects the channel with the fewest access points. In case of multiple access points on the same channel, it selects the channel with the lowest average power level.
Channels with a “w” appended to them are unique to the 40 MHz band. Channels with a “ww” appended to them are 802.11ac specific, and appear only when using an and are unique to the 80 MHz band.channel [smart|acs|random|1|2|3|4|---------128www]
channel [smart|acs|random|1|2|3|4|---------128www ]
| channel | Configures a radio‘s channel of operation |
| [smart|acs|random||1|2|3|4|------ 128www] | Configures the radio‘s channel of
                        operation, using one of the following options:
nx9500-6C8809(config-profile-510TestProfile-if-radio1)#channel 1 nx9500-6C8809(config-profile-510TestProfile-if-radio1)#show context interface radio1 channel 1 beacon period 50 beacon dtim-period bss 1 5 beacon dtim-period bss 2 2 ........................................................................ beacon dtim-period bss 14 5 beacon dtim-period bss 15 5 beacon dtim-period bss 16 5 antenna-gain 12.0 aggregation ampdu tx-only aeroscout forward antenna-mode 2x2 antenna-diversity --More-- nx9500-6C8809(config-profile-510TestProfile-if-radio1)#
| no (radio-interface-config-command) | Resets a radio‘s channel of operation |
